Maytag HN4950T 50 gal Nat. Gas
Wally3128
Maytag 50 Gal Gas W/H, 12 years old, water leaking around the water fittings around the top. My guess...replace. NO valve at the bottom of tank, how do I get the water out to move it ??? :(
  • Replies 4
... is there a threaded pipe plug where the Drain should be ?
Nope, no plug, no nothing. Inlet and outlet on top and relife valve on the side near the top.
Made by State for Maytag!
shown # 3 on Sear's Parts site :kopkrab:
also, see PDF page 9 of HN4950T Installation Instructions
:blush::wallbash::whistling:
DaHHHHH !!! Look behind the cover Dummy !!!!
Thank you SOOOO Much !!!
:thanks:
