GE Dryer DVLR223ET1WW
jambatt
  • Replies 4
Did you remove a wire from the heating element terminal and then ohm from the heating element to the chassis?
... Heating elements come on when timer is moved to any cycle position without start being activated.
also with the Door open ?
Heater partially shorted to chassis ( ground)
Good call guys. :thanks: Pulled drum and element shorted to cabinet.
