Kitchenaid built in stove KGST307HBL9
megadan66
Here I'll start with the part I think it needs
click on picture
Left back burner lights and all 4 spark ignitors spark, but don't when you turn on other burners to light. Ahh but the other burners will light when turned on and you use the left back control to get a spark. I didn't want to take anything apart to check with a meter cause the problem seemed obvious and my service charge is way low and didn't want to put it back together, just to take it back apart to fix it. Am I on the right path to Nirvana. Oh Exalted Ones. Oh and this looks pretty easy to take apart and reassembl. Or do you think I should get the repair manual
  • Replies 6
... Here I'll start with the part I think it needs
yes
And I should be able to get this apart pretty easy......Reg ? I'm good at the art of observing screws and knowing which ones to remove looks like its all underneath where the controls are.
each "Switch" goes on each Burner Shaft
Yea I know, I'm talking bout getting into those shafts. I shouldn't need a manual from what I saw looks like it should come apart easy ay ?
Thanx Reg. I ordered the part from my local parts guy. Will have it next week. And when job is done, I'll through some money in the beer fund !!!
