domo origato
  • TheIslandTinker
  • RegUS_PatOff
I don't know if we have one for that combination of features ...
what area are you having problems ?
The complaint is the temperature is not being maintained in fresh food section--when I arrived the ff section was 50 degrees and the freezer was frosted over. I could not perform the built-in defrost system diagnostics because at some point the tech sheet had been removed and lost. I tested the continuity of the defrost heater, found it to be fine, but I did not know how to force a defrost, so overall operation of the defrost system is unknown. There is an auxiliary "chill fan" in the freezer that was not operating. I measured continuity on it and found it to be open. Not sure if non-operation of this chill fan could cause a freeze-over....ideas?
Do you have the tech sheet at least for this fridge?
Tink
