Do you have the service manuals for these two dryers? They are both built by frigidaire and both electronic control units, and they both will not heat even after replacing the control boards. The heating elements are good and they should heat but don't. I am wondering what the thermister should be at room temp. On the tech sheet is says 50k but both are at about 25k. Any sugestions? If I short out the relay that turns on the heat, it will heat. Thats why i replaced the control boards.
  • Replies 1
  • RegUS_PatOff
  • Rodgers Appl.
any Error Codes (flashing lights) on 417.84052500 ?
Remove wires from the control Thermistor.
Measure resistance of the Thermistor.
If the reading is not 50K (+/- 10 %), replace Thermistor
