How much should brand new furnace and installation cost?
HVAC
I am about to buy a 1200SQ FT house that will be needing a new furnace very soon. The current one is original to the house and needs to go. I realize prices vary based on size,model, and company but i wanted to get an idea of what we can expect to spend and also what others are using and are happy with.
Kay
What size is the old one. If yall thought it was lame go 1 ton higher.
You don't say how old your current unit is, or what climate you live in but if the current furnace is atmospheric venting (chimney etc) - you can expect to shell out in the neighborhood of 10K as many modifications will be required to bring your system "up to code". You will also have a useless cinderblock chimney in the centre of your house as it's services will no longer be required. You will need 80K-100K BTU unit.
