dmanleysr Posted August 18, 2011 Share Posted August 18, 2011 I need a service manual for a model 665.1677993 Kenmore Ultra Wash III Dishwaher. Link to comment Share on other sites More sharing options...
RegUS_PatOff Posted August 18, 2011 Share Posted August 18, 2011 665.1677993valid model number, but I can't find any wiring diagrams for that modelWhat problem are you having ..I may be able to find a model with similar parts Link to comment Share on other sites More sharing options...
dmanleysr Posted August 18, 2011 Author Share Posted August 18, 2011 Need operational drain path. Link to comment Share on other sites More sharing options...
dmanleysr Posted August 18, 2011 Author Share Posted August 18, 2011 I believe it is the same as DU940 produced around 1994-1995. Not the same as the previous DU series or the GU940. Thanks for you help. Link to comment Share on other sites More sharing options...
dmanleysr Posted August 18, 2011 Author Share Posted August 18, 2011 (edited) I found it. Power Clean Moudle #1 4314189. I have a copy if anyones needs it. Thanks for your help. Edited August 18, 2011 by dmanleysr Link to comment Share on other sites More sharing options...
