Kenmore Model # 110.46742701 Sud & F35 Error
I have a Kenmore HE washer model # 110.46742701 that gives me a Sud error as soon as it should be filling for the wash cycle and then it goes to F35.
So, I turn the power button on, the door locks, and the drain pump comes on. When the drain pump stops the door unlocks and locks again and then I get the Sud error. It flashes Sud for about 5 minutes and then the drain pump comes back on and then stops and then the display goes to a F35 error.
The customer said they ran vinegar through the detergant dispenser to clean it out and they ran the rinse and spin cycle several times without any detergant. So, I don't beleive there is a problem with to much detergant in the machine.
I checked the hoses to the pressure switch and the air trap and both seem to be good with no restrictions. I checked all of the electrical connections to the boards and ran a successful diagnostics
test.
My guess is the pressure switch. What do you guy's think?
Thanks, Wan
  • RegUS_PatOff
  • Waneewek
... My guess is the pressure switch. What do you guy's think?
... yes, if you can find one (or the "replacement" part number...)
Not cheap ... :whistling:
Mention that only HE detergent should be used ... and sparingly
There is a work-around pressure switch available ==>
