Need Service manual/tech sheet for this machine if possible.
Whirlpool Duet Sport
Tech Sheet - W10207732.pdf
DUET SPORT.pdf 22 MB
links PM'd
  • 2 years later...
Ab, you gotta help me out here as I am thoroughly confused. Are you and Appguy the same person? if so and if you are using two names, did you check the pm's under the other name? If you are not one and the same, then certainly you cannot expect a private message addressed to appguy to be in your message box.
Also the manual for a duet sport is easily found in the download section... did you search for it?
