Getting this error
flame senced >5 sec without gas valve.
igniter lights up, flame turns on for about 2 sec. then it restarts about 3 time, then blower runs with out flame.
Need your help
Dan
  • Replies 4
  • wernerhouse
  • RegUS_PatOff
Flame Sensed with No Call for Heat.
If the control senses a flame when the gas valve is de-energized,
it will run the air circulator blower and the induced draft blower continuously.
The probable causes are either a short to ground in flame sense circuit,
miswiring, lingering burner flame or a slow closing gas valve.
Could the flame sensor be bad?
could be shorted (always "ON")
That was it!!! The sensor was pressed up against some metal. I installed it poperly and now its working.
Thanks a bunch
Dan
