    • 15 March 2025 02:00 PM Until 03:00 PM
      When: Saturday, March 15 @10:00 AM Eastern Time.
Fisher paykel intuitive dryer DEIX2, fault codes service manual and schematic desperately needed!
Oh most venerable one, please if you would, open my eyes to the baffling wonder of this machine. Machine gave fault 6, now giving fault 12.
Fault Code 6 Door Jammed – (User Warning).
The door is unable to close due to either clothes catching or an excessive closing load.
Remedy: (1) Remove the obstruction.
(2) Reposition or remove some of the load.
(3) Fix the cause of binding in the door closing mechanism.
(4) Replace the motor.
Fault Code 12 Lid Lock Switching Device Failure.
Remedy: Check that there are no short circuits in the lid lock circuit which may have caused the failure in the sensor module.
The resistance of the lid lock should be between 50 and 100 ohms.
If the circuit is correct, replace the sensor module.
service manual
link PM'd
