Can the EC be jumped like the GE board to put unit into defrost?? Heat element shows continuity but unit keeps freezing up. Can't find defrost timer so assume EC initiates defrost cycle.
  • Replies 5
  • jambatt
  • DurhamAppliance
  • RegUS_PatOff
see:
"STEPS TO ENTER ELECTRONIC DEFROST CONTROL TEST MODE"
on PDF page 1 of Wiring Sheet - 2213196
Just curious, why not test defrost limit while you were testing heater? If it passed then replacing the adc board would be a no brainer. I use the adc test to prevent me from opening up evap panel but if I have to expose evap anyhow I'll just test heater and bimetal the old fashioned way. Even it it means I have to splice the bimetal. if I tested the board first, there is a high percent chance I have to open panel anyway (heater doesn't comes on or have to steam defrost to assist heater). Maybe I'm missing the obvious or just don't trust these boards enough.
  • 4 weeks later...
Replaced bimetal and ADC. Unit still freezing up. Cannot get ADC to go into test mode. Bimetal and heater element check for continuity. Can we assume new ADC is bad?? or am I missing something else that would cause it not to go into defrost//
Don't forget that calrod heaters should be tested for continuity and resistance. Resistance should be somewhere between 11 and 30 ohms.
If the ADC won't go into test mode and the defrost components themselves check good, then replace the ADC. Slam dunk ==> Defrost Control Board
