    • 15 February 2025 03:00 PM Until 04:00 PM
      Returning guest presenter Aaron Wilson is back for another exciting discussion. This time, we'll be talking about...
      The Science of CYA: How to Keep the Customer Safe, Document Your Work, and Not Get Sued
      We take on a lot of liability as appliance repair techs, and that can get us into sticky situations whether we've done anything wrong or not. Aaron will be teaching us all about how to navigate this side of the trade.
      We'll start by going over a tragic, real-world case study where a sloppy installation had lethal results, analyzing exactly how the installer's negligence caused this. From there, our scope will expand to what kind of safety precautions we should implement in our own work, both for the customer's sake and for our own.
      But even if you do everything perfectly, there's still the famous "technician witch hunt." Well, we'll also talk about how to deal with that by thoroughly documenting your work and putting yourself beyond legal reproach.
      A little about our guest, Aaron Wilson:
      Aaron has been in the appliance repair trade for about 15 years, starting out by doing installations before moving on to bigger and better things. He worked for C&W Services as a Sub-Zero authorized servicer for a time and thereafter joined Mr. Appliance of Highland Park in the Dallas area, where he worked for years as the lead technician and field service manager. These days, he's making sure that all the appliances of everyone's favorite fried chicken place are in tip-top shape as the Quality and Performance Consultant for the southwest branch of Chick-fil-A. In addition, he has taught many classes on refrigeration repair and advanced diagnostics, during which time he also developed training material for the soft skills side of things, which he is delighted to share with you. On top of all that he's a certified graduate of the Master Samurai Tech Academy, so he knows his stuff!
      When: Saturday, February 15 @10:00 AM Eastern Time.
water in door inoperative.replaced water/ice maker dual solenoid in rear which i can hear operate when water in door lever is pushed.suspect solenoid in door is defective as i do not hear it operate.no mini manual.question is how to gain access to the solenoid?does the plastic trim just pop off?don't want to tear anything up.service or mini manual would be a great help.
Solenoid is in back, in the compressor compartment. Follow the water tubing to the fridge and you'll find it -- it connects to the water valve.
Water valve part link w/video on how to replace ==> Water Inlet Valve
I believe we have a communications failure captain Samurai!!!!!!
Our apprentice said he replaced the water/ice maker dual solenoid in back and can hear it buzz when water dispenser is pressed in front so thinks there's a solenoid in the door that isn't operating.
BMMC, the only solenoid in the dispenser unit in the door is the solenoid that opens the ice chute door, has nothing to do with the water dispenser.
Sounds like the famous GE frozen water line in the door to me...... Probably going to need one of those GE dispenser heater kits.
thank you for correcting me concerning the function of that solenoid in the door.could you enlighten me more about the ge dispenser heater kit?
