MFI2266AEB Maytag French Door
megadan66
Can someone tell me how to get the freezer door out of this Ref. And also what to do if you put in a new mother board and it won't reprogram itself after following tech sheet instructions. Customer had new board and someone else working on this before me. Original problem is evaporator icing up........Thanx
  • Replies 5
  • megadan66
  • certified tech group 51
Door Removal
Freezer Drawer
1. Open drawer to fully open position.
2. Remove upper and lower baskets.
3. Remove screws one in each rail marked on side of rail.
4. Lift front of drawer up and out to remove drawer.
5. Set drawer on a padded surface to prevent damage to finish.
... it won't go into forced defrost mode and heater and terminator check fine ?
that would indicate a bad Controller . . . OR wiring
May have to do some voltage tests while in the Defrost mode.
Did you get the new Controller to "program" ?
OR how far did you get in the programming ?
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad DoorAlarm .
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved.
All the way through with the programming but just beeps at the end and I believe went back to all 0's. The board I replaced was the one in the back of the Ref. Is this the control board. Because I know theres another board in the frezzer door behind the touch pad. Right ?
Lets get a few things straight.. :huh: ..........You replace the board in the rear ... The High voltage board....correct ??? Board in the freezer door???... :kopkrab: ...freezer door is the drawer door...Do you mean the left fresh food door ?? the one with the dispenser, the one with the low voltage board ??? you stated "customer had new board" what did the customer do with the "new board " ???....keep us posted....
