To the dojo,
Please send the service manual for KM DW M#17589200.
Domos in advance,
The Red Grasshoppah
... KM DW M#17589200
would that be a
665.17589200 ?
The distance between the prefix offered by Sensei Reg and the numbers I posted was large; I'm sorry. The model number you list is correct, Reg. Thanks.
No service MANUAL, Sensei Reg? I need to access the thermistor, and put the unit into diagnostic mode.
Heated Dry - Normal - Heated Dry - Normal - Heated Dry - Normal
Thermistor is in the sump (they almost NEVER fail)
That stuff is all on the tech sheet he sent
According to the tech sheet, either the thermistor or the heater leads to LLOOOONNGG cycles (2 hours in my customer's case). The tech sheet isn't clear what's being test in which segment of the diagnostic cycle (compare with the clarity of a KM frontload washer tech sheet). What's been your experience?
standard Whirlpool D/W
KUDx01.pdf
link PM'd
My take is that heaters usually work or they don't - there have been times I have seen them with LARGE calcium buildup that seemed slow to heat, but you'd have wanted to replace it just by looking at it anyway. When considering long cycle times, how much are we expecting to heat the water ? (incoming temp) - and is there adequate circulation of the water to transfer the heat (pump clogs).
I don't really think that 2 hours would be all that excessive having chosen a fully featured cycle (SmartWash is best). The cycle times of some of the newer ones is somewhere around 3 1/2 Hrs - when they oscillate spray arms etc.
Even though the tech sheet says the heavy setting should last 95 mins? The customer's water "burns" without cold, but that doesn't mean it is operating at or above 120 F. How do I test for pump clogs--drain into a bucket, measure drain times?
  • 4 weeks later...
So, after having a nice Advent plate of crow (for changing the sump sensor), I've still got three hour-plus washes. Shouldn't I go through the "seven blinks" fire drill? Check the heat circuit, door latch circuit, and motor circuit? Experience, or, at least, hoots of derision and "I TTOOLLDD you ssoooo"?
