Hi folks, this space shuttle like appliance washes and then dries, at least in theory. When it's supposed to be drying it refuses and quietly says aHE. Being fluent in mumbles, burps and other redneck utterings I immediatly tried to decipher and came up with - "dead Heating Element" but, this is a 120 volt unit and I have 120 volts to ground on both terminals which seems to indicate the element is intact and my "dead Heating Element" translation may be faulty.
All this to ask the question - anybody know what the dHE fault code means? Thanks guys, Sam
  • cuzzin sam
  • john63
Posted (edited)
dHE (Dryer Heating Error)
I am unfamiliar with the MODEL NUMBER (Canadian/UK/Australian?)
I'll hazard a guess that it's a COMBO washer & dryer similar to the US WM3431HW model.
Whenever a 24 inch width model combo unit shows a "dHE" error---the first area to inspect would be the THERMOSTAT wire on the side of the HEATER HOUSING (remove the 2 top covers of the combo unit).
The THERMOSTAT on the side of the HEATER HOUSING is very close/near to the DETERGENT DISPENSER ASSY.
Oftentimes---after a rough spin cycle---the THERMOSTAT has bumped into the DISPENSER ASSY and the *red* wire came off of the THERMOSTAT.
Unplug the unit
Re-install the wire---check for tight-fit on the Thermostat
Grasp the THERMOSTAT and rotate it until the wire connections are nearly vertical (prevents wire from bumping into DISPENSER).
At the top of the THERMOSTAT---slightly bend the connector/wire *downward*---this prevents making contact/shorting against the steel top cover of the combo unit.
If still getting a "dHE" error...
Verify HEATING ELEMENT is "good" (continuity test with multimeter)
Verify THERMOSAT is closed/"good" (continuity test)
Don't even test the DUAL THERMISTORS---never had this fail---ever.
Press & Hold the WASH/RINSE & SPIN SPEED buttons
Then press the POWER button---release all 3 buttons.
The entire CONTROL PANEL lighting should be "on".
Wait 15 seconds for the door WAX MOTOR to *lock* (a lock symbol is displayed on the Control Panel)
Press the START button 9 times at one second intervals
This will send 115-120 volts to the HEATING ELEMENT from the MAIN BOARD for 3 seconds
If 115-120 volts is present for 3 seconds at the HEATING ELEMENT connections---MAIN BOARD is "good"
Press the START button 2 more times---this will energize the BLOWER FAN MOTOR for six minutes.
If the BLOWER FAN MOTOR does not run---remove the screws to the BLOWER and pull from housing. Inspect for lint obstruction/accumulation or seized BLOWER MOTOR.
Edited by john63
Thanks John, I finally got back to look at this machine today - my control panel didn't match up so I couldn't get it to go into diagnostics but I did check the thermostat and found it open, so I'll replace it and go from there. Thanks for the help, Sam
