Hi All:
I have a Lennox G26Q3-75-1 furnace. Just before the inducton motor starts, there is a loud noise (thumb) that seems to come from inside the walls.
At first I thought it was the house moving (getting cold out, figured the house will groan a bit), however this has been a constant thing right before the furnace kicks on.
I've sat next to the furnace listening for the thump..no luck. When upstairs I can hear the thumb quite clearly. And again, only happens as the furnace is about to cycle.
Any ideas?
Glenn
  • Replies 4
  • applianceman18007260692
  • GRS12
  • RegUS_PatOff
Have you checked the return air vent pipe to see if it is loose?
thermal expansion of the vents from cool air entering ?
That is what I am thinking. Is their a rain flap mounted on your inducer vent?
Edited by applianceman18007260692
Gentlemen: Thank you for responding. I've checked all of the pipes/ducts that I can reach, everything seems tight and secure. There is a rain flap, but when the flap moves due to wind or whatever, the sound is quite different.
Thermal expansion/contraction does play a part of this, however, I don't believe all of the thumping is from expansion. Some of the thumps come right before the inducer motor comes on. As I said, I've sat next to the furnace thinking it may be a switch or something, and there is no unseemly noise there when it starts up.
Very odd.
Again, thanks for your replies.
