MDBH965AWS-? Blinking "9" and "Rinse"
vee8power
There may be a version number on the end, but I can't see it. The machine stops in mid-cycle with the rinse lite flashing along with a code "9". There is no tech. sheet in the door nor anywhere. Anybody have a tech sheet for a machine like this, any version might give me a clue.
There is a "Rinse Only" cycle that is 9 minutes long ...
Does the 9 count down ?
Schematic - W10179503.pdf
link PM'd
Thanks for the tech sheet, You ROCK! It led me to the ribbon cable where the pins for "rinse only" cycle are adjacent to each other. I thought the "9" was an error code. All I needed to do was clean the cable. Thanks again :thumbsup:
