Thermador PG486GEBS/11 service manual request - 2nd request - DESPERATE!
Sorry to post this twice, but I can't find anyone except Thermador service to fix this, which costs $99 for the first 18 minutes and then $2/minute after that. I know I'm not as fast as these guys, but I'm way cheaper. I have a gas igniter problem in the aux oven, I think the problem is with the electronics. The /11 means the all gas version of the range.
THANKS!!!
  • Replies 4
  • joedad
  • kdog
  • Spannerwrench
  • johnwernecke
Deleted the other
P/M'd manual
Hi kdog-
The manual is dated July 2003. Not necessarily wrong for my unit bought in 2007, but I think there may be a different one for the all gas model. Do you have anything else?
I've taken off the toe panel and the back cover, i see no electronic switching component compartment as shown on page 47. I think the compartment is only for electric ovens, since there's a timer which I don't have. I don't see any troubleshooting for gas oven problems, or any gas oven components, only electric ones, in this manual.
I have a 4 sheet schematic which I got with the oven, it is named 'PG48 Range Wiring Diagram', dated 08.02.2006, and it is for an all gas range. The sheets are 11"x17". Would it be useful to you if I can scan it?
Even if this is all you have, I am better off than I was before, by a long shot, because there is a troubleshooting chart for the top burners which I will probably need someday.
Thanks!
Joe
  • 2 years later...
johnwernecke
Hi. I would be VERY grateful if you could scan the wiring diagram for PG48. Mine had a grease fire and burned two harnesses a bit so I need to run new wires. Not going to pay Thermador $200 for some 16 gauge wire and connectors.
Start a new topic in the Manual Request and post your full model number.
