Merry Christmas, I have a return call on a Maytag Front Load Washer Model# MAH6700AWW. Customer states that on Warm Wash, everything is fine. On Hot Wash, water leaks out of the Detergent Drawer. I just read this in a similar (MAH8700) Manual:
-Check for possible kinked dispenser to outer
tub hose. Hot water pressurization may force
door open.
Wondering what you guys have found that causes the leaking. Since customer states it only happens on Hot wash, is a fault with the inlet valve or should I simply turn the hot faucet down a little?
Thank You, Bob
  • kdog
  • Adirondack Bob
FYI - just did one of these, This valve will work (less $$$$)
Click on Pic:
