    • 01 March 2025 03:00 PM Until 04:00 PM
      When: Saturday, March 1 @10:00 AM Eastern Time.
I am a little confused on how do the Motor Control test on a Maytag Neptune FL Washer Model# MAH6500AWW. Master k-dog graciously sent me the service manual #16010061.This is copied right from that manual:
Motor & Motor Control Test
1. Set the timer knob into the delay increments.
2. Press the push-to-start switch to start the
washer in the delay mode. Confirm the
delay light is ON.
3. Check for 120 VAC between the L and N
terminals (black wire no.27 and white wire
no. 13) on the motor control board. If not
present, check wiring between the machine
control and the motor control
boards.
4. Unplug the washer power cord. Test cord
to the same board terminals.
5. Remove JP4 Interface connector wire harness
on front end of motor control board.
6. Plug the washer power cord into a 120 VAC
power source. The motor control will immediately
execute a test routine and the
motor should run, rotating the spinner at
50 rpm.
Starting at step 4 is the cunfusion: i think it is an incomplete sentence. Do I take a test cord and plug it into those same terminals? Then at step 6 it says to plug the washer power cord in, not the test cord. Thank You, Bob
  • Replies 10
  • Adirondack Bob
    6
  • RegUS_PatOff
  • kdog
I thinlk it should say:
4. Unplug the washer power cord. OHM cord
Ezzacly right, Brother Reginald. All they're doing in this step is eliminating the power cord as a source of power interruption problems.
Thanks for clarifying that. Now I understand. Happy New Year!
O.K.- Complaint is random LR code. Went to customers today and ran the Service test 4 or 5 times and it passed every time. Customer said this LR code started about six months ago and at first they could Stop/Re-Start it and the cycle would continue.Now it shows up more often and getting harder to clear. I tugged/un-plugged/plugged back in literarly EVERY wire in this machine and did not find anything loose. Then ran another service test and it passed again. I told him to run it through the weekend and call if LR shows again. If the LR code comes back, should I order Motor and Motor Control Board? Thank You, Bob
Does it already have the newer style Motor and Conroller ?
How old is this Washer ?
Thanks Reg, The date of purchase for this washer is 1/08/05. The serial number is 36969141EV. I am pretty sure that this is the first service call ever on this washer.
Did you happen to check for evidence of Tub bearing/Seal wear ?
Yes I did. No tell tale splatter, and I gave the tub a good hard spin by hand. Surprisingly, quiet as a mouse.
Absent any mechanical binding of the drum, then the LR code indicates a problem with the motor or motor control board. ==> Motor and Control Module
Does the drum rotate at 50 RPM when you do the basic motor function test?
***Does the drum rotate at 50 RPM when you do the basic motor function test?***
I know that was the the first question I asked, but no. :fouetaa::deal: This washer was running when I got there. I only did the Service Test....
