Whirlpool # RBD275PD810 DBL Oven I need to calibrate it
Thanks Samuri!!!!!
RBD275PD810
maybe
RBD275PDB10
Bake Temperature Needs Adjustment
1. Select which oven is to be adjusted by pressing the UPPER OVEN or LOWER OVEN pad.
2. Press BAKE pad for 5 seconds. The default temp. 0° or a previously entered offset temperature will show in the Temperature Display.
Press the TEMP pad “up” arrow to increase the temperature in 10° F or 5° C increments.
Press the TEMP pad “down” arrow to decrease the temperature in 10° F or 5° C increments.
Maximum offset temperature adjustment is ±30° F or ±15° C.
3. Press the START pad to save the temp. adjustment.
  • Like 2
Thanks! And yes, it's prolly a B not an 8.
