    • 15 March 2025 02:00 PM Until 03:00 PM
      When: Saturday, March 15 @10:00 AM Eastern Time.
Is there anything you might have on this? mod no 790.75503207. wont bake, element ok. power from bk1. Other leg missing.Cant figger it out w/o roadmap. Help
Ckeck voltage across DLB in control, might find your "other leg" there.
Click on Pic:
not sure which is which. nothing clearly marked as such. there are 2 relays on the back. 1 yellow wire from the element splits to black. Need a diagram.
L1 on controller (usually black) closes to BR or BA for line 1 - Red wire should close between com and n.o. - if 240 volts are seen across com - no while bake or broil is on, replace control
THANK YOU!
Kenmore 790.75503207 made by Frigidaire
318045330.pdf
link PM'd
  • 4 years later...
Can you add that manual to the tech area?
just added once approved
