My Bosch Dishwasher S/N FD7904 210023 has had the intermittent issue with the infamous overheating, and then becoming a "cold", solder joint on the Control Board. It feels like I am de-soldering then re-soldering that same joint every 18 mos or so. Thinking about marginally upping the amps on that component, or just getting a "new" Control Board that hasn't been worked on, by me, yet?? But, not convinced that either will do the trick, longer term, and would like to do some troubleshooting...and do it the right way by consulting the Service Manual. Does anybody have this SM? Thank you!
  • Steve C
  • RegUS_PatOff
.. am de-soldering then re-soldering that same joint every 18 mos or so.
may need to replace the actual Relay ...
BoschDishwasherSearsServiceManual.pdf
link PM'd
Thank you for the suggestion and for the SM!
