Hubby took the dryer apart & where the wiring schematic should have been was empty. Do you have a copy? If so, please send me this much needed info. Thanks so much.
TechSheet P/M'd :thumbsup:
Check blower housing for debris and check the thermal fuse next to it probally has two blue wires connected to it and is white in color, should test closed and if not it's bad!!! Manufactor also suggests to change the operating T-stat next to it if thermal fuse bad!!! Thermal fuse # 3392519 and operating tsat # 3387134
Why did he disassemble the dryer?
What stopped working?
