Whirlpool Double Oven RBD245PDS12 E6/F2 Error Code
Trying to determine if it's the keypad or the control board. The control board has been permanently discontinued. The keypad is available. I'm hoping a service manual will help me determine which is causing the problem.
Thanks!
  • RegUS_PatOff
  • ApplianceMagic
  • jduttinger1980@gmail.com
  • RussTech
Normally if there is a keypad error I think it's a good idea to replace both the board and the keypad. If the board is NLA you can try fixyourboards.com, they may be able to refurbish it for you.
Tech Sheet - 8301761.pdf
link PM'd
Keypad, according to the tech sheet. Try cleaning and re seating the ribbon connector.
Edited by RussTech
