    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
Need Tech Sheet.
kdog, can you try that download again?? Got the following message when I tried to download.
An Error Occurred
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
[#10870] We could not find the file specified
Tech Sheet - 8572216.pdf
link PM'd
Thanks Reg.
None of the LED's will light up. New control board installed. Still no LED's. No response from touchpad. Put in diagnostic mode using instructions in tech sheet (OWI circuit). Still no response from touch pad. Unit starts, water enters, pump comes on and wash cycle starts. Have to turn off at circuit breaker. None of the touchpad buttons lightup or work. Electrical connections OK. Thermal fuse has continuity. Ribbons look OK. Could touchpad be completely dead or could it be something simple that I'm overlooking???
# 1 . Console Assembly
# 2 . Ribbon Cable
# 5 . Interconnect Board
# 11 Electronic Control
all connected properly ?
Merged Topics
Moved to manual requests forum
