Soleus Air SG-DEH-45-1 Dehumidifier not removing humidity
I have a Soleus Air SG-DEH-45-1 Dehumidifier. It powers up and the fan runs but not getting any water in the bucket.
  • Replies 19
  • FDrozd
    9
  • kdog
    4
  • RegUS_PatOff
    4
  • Bullstok
Compressor needs to run as well, will not run in dry or cold ambient conditions
The room is warm around 70 and humidity on the unit says 65. I lowered it and still same. How do you check the compressor? I felt the black cylinder shape item and it felt warm. Tubes leaving it were lukewarm
It needs to be humid in the room to trip the anticipator to start the unit - set control to a lower setting and see if compressor cuts in (should be audible) - try a boiling kettle in front of the unit so as to draw the steam into airflow. If the unit starts there is a good chance it is too dry.
The compressor does turn on. I have had it running about 30 min no humidity being removed. Compressor is not
Sorry Compressor is hot
I have a Soleus Air SG-DEH-45-1 Dehumidifier. The fan runs the compressor also comes on but no water being removed. Please help. Not sure what I need to look for or do. Seems like only the bottom front coil gets slightly cold with a little dampness
... Seems like only the bottom front coil gets slightly cold with a little dampness
the entire Coil should be evenly cold
else you may have a sealed system Freon leak
Grand Master Funk what would my next steps be in trying to repair this unit? What should I be looking for? Is this something that can be fixed?
if there's a system leak, it's usually not worth fixing ..
Thank you
Is there anything else that have these symptoms. I really don't see any oily residue anywhere.
If the Coils aren't evenly cooling, there could be a leak anywhere.
Slow leaks usually don't leak oil.
Topics Merged
Relative humidity needs to be high to cause these to sweat the coils - to test frost pattern, disable the fan and run compressor only - see how the coils frosts
Disconnected fan and compressor ran hot and no coils freezing
:boohoo:Sealed System repair
Is this something I can tackle as an above average tinker person
Service Equipment
Listed below is some of the equipment needed for proper servicing of refrigeration systems.
• Evacuation pump - Robinair, Model 15600 2 stage, 6 cubic feet per minute pump is recommended.
• Four-way manifold gauge set, with low loss hoses
• Leak detector
• Charging cylinder
• Line piercing saddle valve - (Schroeder valves).
• Swagging tools
• Flaring tools
• Tubing cutter
• Flux
• Sil-Fos
• Silver solder
• Oil for swagging and flaring Use only part # R0157532
• Copper tubing Use only part # R0174075 and # R0174076
• Dry nitrogen 99.5% minimum purity, with -40°F or lower dew point
• Crimp tool
• Tube bender
• Micron vacuum gauge
• Process tube adaptor kit
• Heat trap paste
• ICI appliance grade HFC134a
Electrolux makes a very nice training DVD on this if you're seriously wanting to do this ==> http://www.repaircli...4454883/1192226
Never have worked on one. Wonder what the low side pressure should be. Anybody know?
(Schroeder valves)
i think that is the peanuts kid who plays Beefoven on the piano...
