I desperately need the service manuals and anything else that might help get my dishdrawer up and running. My next step is just to throw it off of the patio. Thanks
Those are good machines if you're the kind of person who likes washing your dishes before you put them in the dishwasher. I'm not, but there are lots of people who are. A lot of the FP dishdrawer stuff is due to a) dual water valve going out, B) dispensers going out, c) rotors getting pitted/beat up or d) main board getting corroded or wet. What's going on with yours? Do you have some specific error codes?
  • Like 2
  • 6 months later...
My dd603 just quits randomly during the cycle and shows a"fill fault" error While beeping. Any ideas?
should start a New Topic
Is there enough (any) water in the D/W ?
is it full of water ?
if so check the rotor is still in 1 piece
water valve is unlikely , but when i have changed them in the past it usually fails because they are connected to hot water
i dont rinse my dishes and i works fine
most probs are user related
dispensors are rare
water valves are rare
too much soap is common
bad rotors
  • Like 2
Considering I used to carry a water valve on my truck at all times, and that the F-P factory rep left a box for our techs to toss water valves in because they needed to examine them and figure out why so many dishdrawers were blowing the valve and getting an F1 error code, I couldn't agree with this statement. It may be a regional thing; in the midwest, our water is hard enough that dead dishwasher inlet valves are one of our most common repairs.
maybe its something to do with your water
but in 5 years i can count on 1 hand how many inlet valves i have changed and most have been due to hot water fill
its easy to remember how many i have changed as its such a shitty job to do , right up there with changing drain hoses ;)
