F51 error code. Requesting service manual and interpretation of error code.
  • Replies 5
  • herfdog
  • RegUS_PatOff
This is an intermittent connection at the RPS. Disconnect/reconnect the RPS at least three times to clear oxidation on the contacts. If that doesn't fix it, install the upgraded control which checks the RPS differently to eliminate the error ==> http://www.repairclinic.com/PartDetail/Control-Module/W10189966/1469076?replacedManufacturerPartNumber=W10130544
Service Manual ==>
F51
Motor RPS Failure
F then 51 flashes when there is a motor rotor position sensor (RPS) failure or lower harness problem.
Ô See TEST #3, page 4.
Tech Sheet - W10026634.pdf
link PM'd
F51
Motor RPS Failure
While this is an accurate quote from the tech sheet, it does not reflect the current information from the service bulletin. The corrective action is as I posted.
Thanks for the info and the manual.
You betcha! :dude:
