Matt Johnston
F&P Fridge E442B - Need Service Manual Please
Looking for fault code descriptions and diagnostics info. Seem to have a defrost problem of some kind.
Matt Johnston
Thanks. Can I access the full manual?
I have error code 2.
Is it possible to start a defrost cycle manually so I can check the defost components?
found it !
Fisher and Paykel 790-active-smart-ref-svc.pdf
link PM'd
code 2 is defrost fault
likely reason is faulty defrost element , this can be checked at the controller at the back of the fridge
plug labeled defrost , brown wires , measure appox 160 or so ohms
if element is ok then i would check for a faulty fan
to force defrost press mode button down once and hold and then press temp down button twice
takes about 2 mins for defrost to activate , if you leave the fridge door open you will see the light dim when the relay kicks in
Matt Johnston
Thanks for the info and the manual.
I suspected a defrost fault as it has been freezing up. I have measured the defrost element and checked both fans are operating already.
I will try a manual defrost cycle and see if the element comes on. Perhaps the control unit has failed and is not switching on the element.
