I need the "job aid" manual for this oven. Having trouble with a close door error when starting bake,either oven. Both latches and wiring check ok. Halogen lights will not turn off also.
Correct model number is. KEBC208KWH02
Edited by NCARepair
Please double check model number - have a KEBC208HWH2 and a KEBC208KWH02
Kebc208kwh02 is the correct model number.
Title edited
See the Techsheet posted here - this unit also has a "sisterboard" involved in the door circuit
I was hoping to get a manual that's more in depth. The sister board handles the door lock motors.
Link says i dont have permission,file not found. Could you pm the file?
Download is in the que awaiting Samurai's approval, check link again later it will be active
Perfect. Thanks for the quick response.
It's locked and loaded ready for you to pull the trigger. :armed:
Thanks for the manual!
