Unhappy wife = unhappy life
Need to fix the fridge soon - trying to find the manual.
thanks in advance
KBRS22K
KBRS22Kxxxxx
121 different models ...
What's the problem area ?
sorry - KBRS22KGBT4.
Freezer works, warm fridge and no fan sound.
Cleaned underneath and let it sit unpowered 48 hours - no change.
I'm thinking fan motor based on the troubleshooting flowchart posted hereabouts - I just feel better digging in if I have diagrams to know where I'm going.
both Fans should run when the Compressor is running
KBRS22KGBT4
Wiring Sheet - 4344141.pdf
link PM'd
KBRS22KGBT4
link PM'd
So if I'm hearing no fan noise whatsoever, should I be looking at the compressor?
Freezer Temperature Control (and through Defrost Timer)
controls the Compressor and both Fans.
Is the Compressor or either Fan running ?
Nope - no noise whatsoever. By the way, thank you for the help if I forget to say so later!
how can the Freezer work without the Compressor working ?
That's what I was thinking too so I tested it overnight and it isn't. I must've caught it right after it failed and before the freezer compartment had a chance to warm up.
So no sound or cooling anywhere.
either it's in a 25 minute Defrost cycle,
bad Defrost Timer,
OR bad Freezer Cold Control
Forgive me if this is a stupid question, but by "freezer cold control" do you mean the thermostat?
yes
Thanks. Are both parts fairly obvious behind the freezer liner, or will I need diagrams?
Good call on the thermostat - that fixed it. Thanks again for the help!
