790.99114301
Rodgers Appl.
do you have a service manual for this frigiidaire built range? the cook top isn't working and it is displaying an f5.
Hard to cross over from a Kenmore model number to its Frigidaire equivalent but, in general, for Friggys...
F5 The watchdog circuit is active when it should be disabled. The microprocessor checked for operation of EOC relay after selection of Bake, Broil, or Clean operation and relay failed test. Check for shorted keypad or pushbuttons binding in glass and stuck. If not replace EOC.
