rcrcowboy1
It would be worth a 30 pack for a service manual.Thanks for any help.
MG
Looks like an Old Skool unit
not quite, but I'm not sure what it is, still looking
DU018DWTx
c.2008
starting to look like a Frigidaire or GE made for Whirlpool
That doesn't look anything like the newer 18" Frigidaire dishwashers.
Possibly Danby - never worked on one but saw something similar to that in a local appliance store and I believe I've seen one like that in the scrapyard, recall it being Danby or some other foreign type built.
Should not have doubted RegUS, (you really know your stuff).
I guess I've never seen the new 18" Frigidaire units, I was only familiar with the 18" design before this model, with the vertical mount motor with plastic shaft that would melt down when the drain impeller got jammed.
  • 8 years later...
I'm on one now same model. Has a relay on frame under tub next to inlet valve. Relay clicks when start/resume pressed. No other response while advancing timer. No schematic of course.
Getting .9a and 3.7a flipping through timer. Heater and locked drain pump?
Edited by johnsavit
Spelling
