    • 15 March 2025 02:00 PM Until 03:00 PM
      When: Saturday, March 15 @10:00 AM Eastern Time.
northcaver
Please send me a repair /dignostic manual for Bosch washer WFMC 530CUC/10
need to diagnose why it isnt spinning (not off balance)
Thank you!
northcaver
Thanks for the links kdog, but I am having a problem using the diagnostic test on my washer model..WFMC 530cuc/10...are there any other manuals available that would have the diagnostic routine for this model?
northcaver
Sorry kdog, forget my last post...i'm figuring this out ;-)
northcaver
Groan...I thought I had it figured out..not. I follow the diagnostic prescribed routine to pull the error codes off of the machine, and I cant get the bugger to do it...it just stays lit as if I am going to start a load of clothes. what am I doing wrong? Anyone????
WFMC53
Entering & using WFMC32/33/43/53 test programs:
•To reset, rotate cycle selector knob to OFF position.
•To enter test program, push and hold SPIN SELECTION and DELAY START buttons at the same time,
then rotate cycle selector knob CCW to PERMANENT PRESS COLD position.
Continue holding SPIN SELECTION and DELAY START buttons until P:01 shows in display.
•To select tests, push SPIN SELECTION button (to scroll through tests) until desired test shows in display (P:01 - P:17)
START/PAUSE light will flash.
•To start tests, push START/PAUSE button while its light is flashing -- light stays lit when test has started.
To end tests, push SPIN SELECTION button.
•To exit test program, rotate cycle selector knob to OFF position.
