Click here to take the quiz.
Temp display on front panel shows correct target temps, however, refrigerator is not running, and temps inside R high.Unplugged , plugged ref back in. Now front panel temps(high) r correct. N compresser n C-fan n E-fan R running. Unit cools to corect temps. It shuts off. And to get it to work right ya haveto unplug/plug in again. Repeat cycle forever.
Won't U please,please,help me........Megadan
  • Replies 15
  • megadan66
    9
  • RegUS_PatOff
  • kdog
Nobody wants to touch this wirth a 10 foot pole. huh lol
I would guess it is one of these (cheap enough you can shotgun it) :
did you do the tests on PDF 38 ?
Not yet. will tomoro. Customer is real cool. He's gonna let me learn. Rather than thinkin I got a magic wand. Let ya know what find thanx fer ur support.
R u talkin bout the self diagnostic in the service manual u sent me ....Reg ?
the manual tests / diagnostics
Will do
Closest you'll get to a magic wand on these electronic refrigerators is to RUN THE DIAGNOSTICS. You're absolutely flying blind without doing that.
Having said all that, based on the problem you're describing, I would go the GMF kdog route and replace both the sensor and muthaboard.
Which sensor frezer or ref and even if they test ok with a meter. self dio gave me zeros, nothing bad thanx for the help. watz gmf mean ?
Um any chance someone can answer my last ? . I need to know by mon. Got the board and a sensor from RC. Thanx always for the help !
For the price of the sensor, I would replace both.
... self dio gave me zeros
which test (page number ?) were you checking ?
Sensors are $ 7
If they don't fix the problem change the Main Control Board
page 23 9-9 #2 Yea I know the price of sensors. I bought a board and one sensor already from repair clinic. Going back to customers house tomoro changing the board and a sensor, since I only have one sensor at this time. which sensor should I change ? This unit has 5 sensors.
Edited by megadan66
  • 3 weeks later...
Turned out to b the sensors. changed all 4. Thanx fer the help always....Dan
