Please help. This is the Axxis condensation series, no conventional exhaust. All sensors check good per ratings on wiring schematic. Replaced heater, one leg was bad. I now get heat but only for about 5 sec. at a time. Service manual, training guide, theory of operation would be helpful. I'm guessing it's an issue with air flow/pressure, the filter coil, or maybe the board. The unit will run w/no heat as if sensing, then reverse rotation for a few seconds while activating the heater, the heat produced is weak, it will then rotate in the original direction again for a period of time & repeat. its almost as if if the heater function was reversed it would be functioning perfectly.
  • Replies 5
  • RegUS_PatOff
  • DRT1200
  • yjlee
  • robertparker
WTA35-WTL54svctrng(r2).pdf
link PM'd
Sensei,
Any chance of you pm'ing this to me also?
Do you have any new Bosch stuff of the stash?
done
Not enough heat for WTA3510US Bosch dryer. Definitely 2 heating elements are OK. But not enough to complete drying opearation. It seems the dryer turn on 800 W heating coil for a long time, abd turn on 1900 W heating coil for a short time. Could you send me the manual to understand and repair the Bosch dryer?
check & clean the Vent.
What's the Vent temperatures ?
service manual sent
