To the Dojo,
If we are to avoid ISC work as the hari-kari-like sentence it is, how can a non-ISC appliantologist like me keep up with ALL company service bulletins and updates for factory-created boo-boos? Could one of the certified Masters start a forum for such wisdom?
I feel I should be practicing on refrigeration and circuit board-related repairs; junkers would be a good start, right? What method(s) do you guys use--junkers again, home study (which one)? What is a good home-study curriculum for electronics, or should I go to tech school (keep in mind I'm a working journeyman appliantologist)? What are some go-to tools for electronified appliances?
Thanks in advance,
Tyrus (aka RedToryTy)
  • 2 weeks later...
  • jb8103
  • RedToryTy
I'd say tech school, if your local community college offers HVAC. I got a pretty good grip on electrical from the program I took.
Seems to me, no tech schools offer appliance repair. I look for this to change soon because we are definitely past the pliers-and-screwdriver level.
I also bought and scrounged a few scrap washers and dryers, rebuilt them and made a bit of profit. Good basic learning experience, but junkers will be old technology.
You really don't need to know and understand electronic circuitry to troubleshoot. It can be helpful for insight but it's not a crucial skill because really all you're doing is checking for input and output voltages on a board. As long as you have those specs for a given board/model then you can usually make a proper diagnosis. You're not troubleshooting to a bad component on the board because you're not repairing the board-- you're replacing it no matter what's wrong with it. So, if you can use a multimeter and read a wiring diagram/tech sheet, you can troubleshoot electronified appliances!
Exactly right (as per usual). The board is just a black box to us, aside from some that have replaceable relays.
And we could say the same about sealed system work. Being an HVAC tech, I have the tools to deal with refrigeration systems. Recovery pump, vacuum pump, manifold gauges, all the hoses, recovery cylinders, pressure regulator, nitrogen cylinder, a good $1200 invested, plus the license to buy refrigerant. But it should never come up in appliance repair - we just need to know when and why the sealed system has failed.
But if you want to know more about motors and controls, tech school is the way to go.
