Need tech sheet/service manual.
Hey US Reg, can you help me out here. Owner lost the tech sheet.
Thanks Reg. Unit sat idle for several months with water cut off to house. No water coming in. Units sump was dry. Replaced water valve with same result. No water. Hand filled sump with water and ran machine through cycle. Unit now works fine. :kopkrab: Must be some type of water sensor involved somewhere.There doesn't appear to be any way to access the pump and other parts without removing the entire plastic base.
You can remove the right and left side panels to check components.
You have to drop the base to change several components.
