Owner says unit shuts off and shows Red F2 and Green E1 fault code. Hit Clear/Cancel and unit will come back to life. Also said unit will show Set Temp Probe when humidity is high even though probe is not connected. Service manual says F2 and E1 are problems with touch pad. Is this problem a result of the touchpad issues or is this a control board problem? Either way this is a damn expensive fix.
Edited by jambatt
  • jambatt
  • RegUS_PatOff
Anybody out there had any experience with one of these???
  • 1 month later...
Still got this one on my list. Any suggestions would be appreciated!
F2 E1 Keypad not connected
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad
(may be dirty / corroded ribbon cable connections)
Probe:
disconnect P5 at Controller Board and measure high resistance (leakage) between (at the) Probe connections
or the cable P5.4 to P5.5
If bad cable, and Probe never used, just disconnect those two wires at the Controller.
any parts ordered from RepairClinic can be returned for a refund (less shipping)
including installed electrical parts
Membrane Switch, Stainless Steel
click on picture $ 258
click on picture
