service manual request: Dacor Range Model# ERD48SCP
hello, i am looking for a service manual for a decor range, model# ERD48SCP
thank you.
  • Replies 6
  • appliance repair tech
    4
  • RegUS_PatOff
what's the problem ?
hello, symptons are f2 fault code appearing intermittantly, temperature not maintaining to set point and some relay can be heard clicking away rapidly at times, if oven is set at 350 degrees, it will preheat fine, and while monitoring temperature with a digital thermometer and a thermocouple in oven i can see my high end at approx 368 degrees and low end at approx 314 degrees and this is normal, but then i will watch the temperature and sometimes on the climb back up and it will only go as high as 320 degrees and a low of around 300 degrees and this is not a normal cycle when the set temp is 350 degrees and the end result is food that ends up undercooked so i am lookimg for a service manual to see what decor is suggesting for diagnostic testing to determine solution.
also the cooling fan for the electronics is turning on at the proper temperature of approx 190 degrees to keep the electronics cool.
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds “runaway limits”.
The ERC will beep until the cancel or another function is selected.
If the alarm repeats the F2 alarm check the oven sensor and wiring after first checking for a stuck relay.
If alarm goes away verify the oven will complete a clean cycle without any type of failure.
Classic ERC Failure Codes Back.pdf
Diagnostic_Manual.pdf
links PM'd
hello, the pssible stuck relay that the f2 fault references to , is that a relay on the erc or on some other relay board in the oven, also is there any type of manual that shows the parts layouts or schematics or dissassembly procedures that are available, thank you.
PM_ERD48_2012-06-11-Web.pdf
link Pm'd
THANK YOU FOR THE LAST PM SENT TO ME OF THE PARTS CATALOG OF THE DACOR RANGE THAT I AM WORKING ON, ALTHOUGH IT SAYS ITS A PARTS CATALOG IT GIVES GREAT VISUAL OF BOTH THE PARTS AND LAYOUT OF EVERYTHING, AGAIN THANK YOU.
