Click here to take the quiz.
RHEEM 12 Condenser Fan Overheated
L Ron Hoover
Rheem 12 AC unit had the condenser fan stop. Evidently it the thermal cutoff was tripped. Reset and has yet to trip again. Current running 2.4-3.0 amps and spec states should be 2.0.
Possible causes? It was 102 degrees today here in Texas. I cleaned the housing off to ensure get air flow through the unit.
Do you think the motor needs replacing?
  • RegUS_PatOff
  • tommytech
  • L Ron Hoover
unit model number may help
Fan Motor Capacitor may be bad
It's part of the Dual Capacitor.
With power removed, try turning the Fan Motor Shaft (or Blade) by hand.
Does it turn easily, smoothly ?
can you give it a spin, and it will continue for a few revolutions ?
let the fan run for about 20 min,then check amp draw.if above rated draw inc. + /- %, i would replace motor and cap.
