Service Manual needed for WFW9600TW01 Whirlpool Front Load Washer
  • RegUS_PatOff
  • dmanleysr
  • JoanDamico
Tech Sheet - W10133490.pdf
link PM'd
wfw9600tw01 f35, need manual
link PM'd
F35 ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
click on picture
