My dryer is acting up
  • Replies 4
  • mf4880
  • RegUS_PatOff
What is the difference between the dryer you provided a manual for, which is DLE7177WM.
My dryer is a DLE7177RM.
It is an electric dryer and it is slowly not drying the clothes.
It has gotten gradually worse.
Now it will hardly dry at all.
It runs the whole time just not enough heat
Edited by mf4880
... What is the difference between ... DLE7177WM ...My dryer is a DLE7177RM.
... Now it will hardly dry at all.
1) DLE7177WM is white, DLE7177RM is red
2) how's the Vent ?
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
click on picture sometimes on sale for $ 2.99
I will dig into it. I know the vent is only about 2ft long and all rigid pipe, no screws.
Thank you for the model # insite.
