I have a Whirlpool window AC/heat unit, model ACE184XPO. The unit is cooling too much! It is not cycling off. Suspect maybe the thermostat, but not sure. Once last winter, heat did not shut off, room was so hot everything in it was warm to the touch!! Nobody is servicing window units in this area anymore, is this something I can repair myself?
  • horsezfarm
  • jb8103
Is this something that is fairly easy to change out?
For that unit, the guts should slide right out of the metal cabinet. Remove the plastic grill - you may have to refer to your installation manual to find out how to do this without breaking it. The thermostat bulb will be dangling right in front of the evaporator. Trace the copper line from the bulb back to the thermostat. Slide the thing out if you have to, it's no big deal.
