EI28BS56IS Electrolux Refr. manual needed. Note "i"s, not "1"s in model number.
I have PDFs for a tech sheet, a parts guide, an owner's manual and some flashes on this refr.-- but no service manual, which the tech sheet refers to when you wonder why the diagnostics are saying the icemaker is off (It's not). Yes, it did move. The freezer seems plenty cold to rule out freezer recovery mode.
This is one of those entertaining (to watch) little finger icemakers that are such an exercise of language to work on.
Refr. appears to be fine other than no ice making. Water dispensed is not cold- I guess that's what the ice is supposed to be for.
Thanks for trying, Reg. I'll try attaching a parts blowup of this icemaker. You can think of this as rotating a row of hollow cylinders out from the fill tube down and then up over the hanging tube evaporators that freeze the water. Then the cylinders heat up, rotate away from tubes, and the ice slips off the the finger evaporator tubes when they do a hot gas defrost.
post-39348-0-74545500-1346143333_thumb.g
