service manual please, this one has no front bottom pannell that you can remove.
P/M'd Affinity Service Manual
tech sheets
134604100ts_wd_efs.pdf
link PM'd
What's it's problem ?
THANKS FOR THE TECH SHEET AND MANUAL GUY'S. THERE WAS A BRA WIRE IN THE PUMP. I'VE SERVICED A LOT OF THESE AND TO BE HONEST THIS WAS THE FIRST ONE I'V SEEN THAT DIDN'T HAVE A FRONT ACCESS PANEL. SO I WANTED THE MANUAL TO SEE IF THERE'S ANY WAY TO SERVICE SOME OF THIS MACHINE FROM THE FRONT.
No way to service from the front except by removing the complete front control console to remove front panel, (you don't want to go in that way).
These aren't too bad to do from the rear, just wear a long sleeved jacket and/or lay a towel over the opening area in the back so you don't slice your arms up.
I believe you can also access from underneath by tipping machine back also, (the bottom has a cutout to access pump), but as long as you can access from the back I've found for me that is the preferable method.
  • Like 2
thanks iappreciate your help.
