DWSR483EB0WW Need Manual For Re-assembly!
richseattle56
This is a GE Dryer. Customer brought me this dryer with the left side removed. And parts missing. Customer replaced dryer motor when dryer would not start. They dont know if the motor is wired correctly.
Any help would be appreciated
Edited by richseattle56
  • Replies 37
    19
  • richseattle56
    19
OK I got it back together. Does any one have a wiring digram that shows which color goes to which post on the motor.
Ok The wiring that was sent are not all the same colors.
I took pics of the way its hooked up now and a pic of the wiring diagram. They are attached.
So here is what it is wired like now.
Pink on the bottom which I think is #1 goes to idler spring switch
#2 Brown goes to hi limit Thermo
#3 Red W/ Black Stripe goes to the front panel I assue the mositure sensor/ and a black wire that goes to the Terminal block
#4 Dark Yellow goes to Door Switch
#5 2 pink wires one to the Cycling Thermo and one to the element
#6 Yellow ground does go to ground
Can you help from this. I hope so.
Thanks
post-59945-0-61715300-1348877619_thumb.j
post-59945-0-27061600-1348877695_thumb.j
OK the wiring that the other guy did, as soon as you plugged the dryer in the motor word buzz. I used the wiring diagram on the tech sheet and now it does not buzz but the motor and heater comes on as soon as you turn it to any cycle start switch is not shorted it test good. I must have a couple wires messed up. The new motor is part#
WE17X10010. Repair Clinic said that it comes with instructions how to put in my customer says it did not come with any instrctions. Does anyone have thst sheet, or have a suggestin on how I can get it?
Any help would be appreciated.
I've been searching ...
many people with the same problem ..
that Motor (from the kit) is only used on a few GE models ..
OK... looks like
. . . . . . . M6 ... M5 ... M4 ... M3 ... M2 ... M1
. . . . . . .Pink . Red . Brn/Yel . . . Purple . Black
Should I go by the diagram from manage my life on an earlier post, for what the numbers are ie. M1 M2
These are the color of wires I have:
(2 wires)Red W/ Black Stripe goes to the front panel I assue the mositure sensor/ and a black wire that goes to the Terminal block
(2 wires) purple wires one to the Cycling Thermo and one to the element
Pink wire goes to the belt switch
1) Brown goes to hi limit Thermo
2) (2 wires) Red W/ Black Stripe goes to the front panel I assue the mositure sensor/ and a black wire that goes to the Terminal block
3) Dark Yellow goes to Door Switch
4) (2 wires) purple wires one to the Cycling Thermo and one to the element
5) Yellow ground does go to ground
6) Pink wire goes to the belt switch
1) doesn't Brown go through the Idler Spring Switch (and turns to Pink) before it gets to the Motor? >>> Pink would be M6
2) I only see one Red/Black wire and it also connects to the larger Black Wire from L2 power >>> M1 (Motor Centrifugal Switch)
3) wiring diagram shows Door Switch wire is Brown/Yellow >>> M4
4) Heater Element Purple >>> M2 (Motor Centrifugal Switch)
5) Yellow is Neutral >> doesn't go to Motor Connector
6) Pink >>> M6
no motor busses when i plug in but does not start. This motor wiring is different then old motor, so I guess the tech sheet is usless.
6) Pink >>> M6
is the above true ?
post better (angle) picture of your connections to your Motor
Do you have any pictures or notes about the connections on your "old" Motor ?
it could be:
. . . .wires of the Motor . . Blue . . . . .Orange . . . . .Black .
. . . . . . . M5 ... M4 ... M3 ... M6 ... M1 ... M2
. . . . . . .Red . Brn/Yel . . . Pink .. Black..Purple
are the Motor terminals numbered ?
Just the tech sheet. I maybe able to get the Instruction Sheet for the new motor from my local parts company. But that wont be till monday. This motor is wired differently from the old motor. Yes the motor terminals are numbered.
1 at far right on picture through 9.
This site shows a different combination for M1, M2 etc. but when I hook it up that way the motor and element come on as soon as you put it on any cycle.
http://www.managemyl...-motor-ge-dryer
can you post a picture of your "new" Motor that shows the terminal numbers ?
and a photo of the Switch shown at managemylife
Tried latest configuration you sent me still motor just buzzing as soon as I pluged it in. If you goto the managemylife post link'd above you can see the numbering of terminal posts, click on the picture and scroll down to the bottom of the pic.
Also if I hook it up according to the managemylife page the motor and heater come on as soon as you put it on any cycle. I dont have a blue so I put the purple on that terminal.
6) Pink >>> M6
is the above true ?
do you have pictures (or notes) of your "old" Motor (Switch) before the wires were removed ?
and what wire colors do you have on the Motor...
your wiring diagrams says:
Red from Start Switch
Brn/Yel from Door Swtch
Pink from Idler Spring Switch
Black from L2
Purple from Heater Element
have no red.
Other than no red the above what was last posted is correct.
No notes or picks of previous motor wiring but the tech sheet I posted shows the original.
have no red.
I see some Red wires in the pictrure of your Motor you posted ..
Your wiring diagrams shows Red
There should be (5) connections to the Motor ...
What color wires are they ?
richseattle56
pink to idler arm switch
yellow to door switch
purple to element and cycling thermo
brown to hi-limit thermo
black to terminal block/ (a red wire with a black stripecomes off the black wire connector goes to I think the door light. It goes inside door frame.
Did you look at theTech sheet I posted about how to wire the newer style motor?
(earlier, you said Yellow goes to ground)
you're missing wire (Red ?) to Start Switch
richseattle56
White goes to ground
