I have a double oven, range that both the ovens are not reaching temperature. It has nine gas burners on top, and, the ovens are electric elements. Elements are getting 220 volts. Any thoughts on what the problem may be? I need the service manual before I tear into this one.
  • Replies 5
  • tpoindexter
    4
  • RegUS_PatOff
.... Elements are getting 220 volts. Any thoughts on what the problem may be? I need the service manual before I tear into this one.
If the Elements are getting 220v, they'd be getting hot, unless they're bad.
How are you measuring 220v ?
Tech Sheet - 8302546.pdf
link PM'd
Sorry, I misspoke. I checked the power at the outlet and got 220 volts. Since I'm unfamiliar with the unit I wanted the service manual before I tore into it.
either a problem with the Thermal Fuses on the back wall of both Ovens
(self-clean used lately ?) :nono:
click on picture
OR
a problem with (red) L2 line power
It confused me because it was both ovens. When I get it out and apart I will check out the red wire. Thank You!
  • 4 months later...
Thank you RegUs.
The fuses fixed this back in October. Just thought I'd update before making my next post.
